What is the largest capacity hard drive that I can fit in a Hikvision NVR?
Phil
Administrator
Staff member
For a year or three(!), the largest capacity HDD that would work in a Hikvision NVR has been 14TB.
(old thread here)
In some new product datasheets we saw mention of 16TB being the largest capacity HDD that they would accept.
We have checked with Hikvision's UK Tech Support and they have confirmed that 16TB HDDs can be used now.
If we get more info on specific compatibility we will add it here as & when.
Meanwhile, HDD manufacturers are closing-in on 30TB drives ...
(obviously, at bleeding-edge prices)
One year on, and this topic is due an update.
Hikvision have just released their new large Super H Series NVRs.
Those NVRs can accept a 20TB HDD (up to 24 in one NVR!).
Only this Seagate Sky Hawk AI 20TB hard drive has been tested and approved by Hikvision (select the 20TB variant from the dropdown on the linked product page).
In establishing that fact, we learned that a few other NVRs are also now able to accept that 20TB HDD.
Please see the table below for further details of which Hikvision NVR range can accept what capacity of Seagate Sky Hawk AI HDD:
Y=Compatible
N=Not compatible
Backend Products
ST1000VX013
ST2000VX017
ST3000VX015
ST4000VX016
ST6000VX009
ST8000VE001
ST10000VE001
ST12000VE001
ST16000VE002
ST20000VE002
[DVR] iDS-72HQHI-M & iDS72HUHI-M (K20A9)
Y
Y
Y
Y
Y
Y
Y
N
N
N
[DVR] iDS-73/81/90xxHQHI-M &
iDS-73/81/90xxHUHI-M (K21B1)
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[DVR] Turbo 5.0
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[DVR] Turbo 4.0
Y
Y
Y
Y
Y
Y
Y
N
N
N
[NVR] DS-76 77 96 NI-M (K21B1)
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
[NVR] DS-76 77 86 96 NXI-I (K22B1)
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
[NVR] iDS-96000NXI-I (X50+KT2)
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
[NVR] DS-96000NI-I (X50)
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
[NVR] iDS-77 86 88 96NXI-I
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[NVR] DS-76 77 86 96NI-I
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[NVR] DS-76NI-Q & 76 NI-K
Y
Y
Y
Y
Y
Y
N
N
N
N
[NVR] DS-76NI-Q(C) & DS-76NI-K(C) (K9B2)
Y
Y
Y
Y
Y
Y
N
N
N
N
[NVR] DS-76 77NI-Q & 76NI-K (K21B2)
Y
Y
Y
Y
Y
Y
Y
N
N
N
[NVR] DS-76 77NI-K (D&E) (K20A9)
Y
Y
Y
Y
Y
Y
Y
N
N
N
[NVR] DS-76 77NXI-Kx (K20A9)
Y
Y
Y
Y
Y
Y
Y
N
N
N
Hikvision have thus far only tested Western Digital HDDs up to 18TB - below is the corresponding table for the WD drives:
Backend Products
WD10PURZ
(WD10PURX)
WD11PURZ
WD23PURZ
WD33PURZ
WD43PURZ
(WD42PURU)
WD64PURZ
(WD63PURU-78)
WD85PURZ
WD8001PURP
(DS82HKAI-78GVLY0)
WD101PURP
(DS102HKAI-78WCLY0)
WD121PURP
WD141PURP
WD181PURP
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[DVR] 7204HGHI-K & 7208HGHIK (K9B1)
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
[DVR] Turbo 5.0
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
[DVR] Turbo 4.0
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
[DVR] Turbo 3.0
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
[DVR] Turbo 3.0 -F for RAID
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
[DVR] Turbo 1.0
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
[NVR] DS-71NI-Q1
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
N
[NVR] DS-71NI-Q (C) (K20B2)
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
[NVR] DS-78 79 86NXI-Kx (K20A9)
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
N
N
I have also attached the latest available Hikvision HDD compatibility document pdf (87 pages).
Pages 2-6 explain which NVR & DVR models fall within which category used within the document for detailing HDD approval.
If you find your model in the right-side section there, then the category title at the left-side is usually a hyperlink to take you to the document page for your device.
At the head of that page/section device model numbers are confirmed.
Within the section for your device you will find the hard drive models that Hikvision have tested and proven with your device.
WD = Western Digital
ST = Seagate
MG = Toshiba Enterprise [NB the 5yr warranty on this Toshiba range]
