The capacity of microSD is something that is continually increasing at an astonishing rate, with cards as large as 2TB starting to become available. As almost all new Hikvision IP cameras have memory card slots for onboard storage, and you would have traditionally needed an NVR with hard drives to provide terabytes' worth of storage for your cameras, having this amount available for storage at the edge can be incredibly useful.
The datasheet for a Hikvision camera tends to show the maximum size of microSD card that they've tested and verified works in the camera, but this can be quite variable.
So, we decided to pick up a 1.5TB SanDisk Ultra microSD memory card, which we have been testing in one of Hikvision's new DS-2CD2087G2H-LIU 8MP Smart Hybrid Light Mini Bullet Cameras for a couple of weeks, and have been pleased to find that it works perfectly.
With the camera set to full resolution, 25fps, 'medium' video quality and using H.265 encoding, we've found that the 1.5TB card was enough to store 32 days' worth of footage from the 8MP camera.
Of course, if you use the H.265+, you'll be able to stretch this even further.
However, you will get fewer days from the card if you increase the frame rate, record audio, set the video quality to 'higher' or 'highest', or use the H.264 or H.264+ codecs.
Please note that we have only extensively tested this 1.5TB card in a hybrid light camera, and cannot yet guarantee they will fully work on earlier models.
However, we can confirm that the 2xx6G2 (C) and 2xx7G2 (C) correctly recognised and formatted the card.
The table below summarised what we have found so far concerning compatibility - we'll update this as and when we confirm that they can record for extensive periods on the card without any issues, and also add any other cameras we're able to test:
If you have any questions or findings you think may be helpful, please feel free to post them below!
Updated 22nd January 2025
1.5TB microSD recognised correctly and formatted | Extensive recording period tested without issues | |
DS-2CD2xx7G2H Hybrid Light Models | ✔ | ✔ |
DS-2CD2xx6G2 (C) Acusense IR Models (G5 Platform) | ✔ | ✔ |
DS-2CD2xx7G2 (C) ColurVu Models (G5 Platform) | ✔ | ✔ |
DS-2CD2xx6G2 Acusense IR Models (G3 Platform) | ✔ | ✔ |
DS-2DE4A425IWG-E PTZ | ✔ | ✔ |
DS-2CD2xx5G1 IR Models (G1 Platform) | ✕ | ✕ |
DS-2CD2xx5FWD IR Models (G1 Platform) | ✕ | ✕ |
DS-2CV2xx1G2-IDW(W) Wi-Fi Models | ✕ | ✕ |
