Poe cctv - adding a camera at the end of my garden?
Markus19
Hi guys ive got a hikvison 4 channel nvr got 2 cctv connected hard wire straight to nvr looking to add a 3rd but it is abit away and dont want to run a direct cable what are my options ?
Many thanks
How far is 'a bit away'? If the budget was available - you could have a POE powered switch at one end connected to a wireless bridge - which then connected to the other end of the wireless bridge - and then to your NVR...
Hello thanks for reply.
Its down the bottom of the garden say 100ft from the house and the nvr is at the front of the house .
The poe cctv i have has the rj45 connection for poe but also has a dc power option.
So like you say could i plug in the cctv via dc connection then rj45 patch lead from camera to wifi bridge then at the other end wifi bridge patch lead to nvr ?
Would it matter my nvr is poe ports ?
Also when you say wifi bridge what is a good option would the like of a Tp link work or do i need something with a certain spec
Thanks alot
Do you have power available at the bottom of the garden? If so - over a 100ft is certainly doable with a bridge....
