Hi from Australia,
I have been searching around for an IP camera for a while and decided on a Milesight setup.
Their is limited info in Oz about these but I liked the look of there mini NVR and the dome cameras.
I purchased an MS-N1009-UPT, 4 x MS-C5375-PB's & a 4Tb WD purple.
Updated the firmware on the NVR to 72.9.0.2-r3 and a camera to 41.7.0.67-r14. Also changed my passwords
I have installed 1 camera and temporarily run a 15m cat5e cable to the NVR and then a 1m cat5e cable to the router which then runs to the fibre optic modem in cat6.
The setup was OK but struggled a little with the networking, I'm technically minded but it has been a few years since I've played with networking. I setup DMZ in my Telstra (Aus ISP) router. I read this on a Telstra forum.
I can use the m-sight pro app on the phone, smart tools on the computer which is on the same LAN and connect to the NVR from computers external to the LAN. I also have a monitor plugged into the NVR.
I am just chasing some answers, I'm confused with:
Can someone give me a rundown with the networking in regards of how to make sure my LAN is secure with DMZ, I did a little bit of googling and I don't understand how it works. I have all the 'network' menus in the NVR turned off (IPv4, IPv6, UPnp, DDNS, P2P etc).
How the camera has stutter. When I look at my NVR directly and my 1 camera the feed stutters. I can't figure out why?
The photos of my settings are attached. It looks like the FPS drops.
I have tried lowering my bit rate and MP and there is still a stutter also in the recorded footage when I look back.
I haven't tried another camera yet.
Ill have many more questions as I learn more.
Sam
Sam
