mentalmike
I have installed two DS-2CD2346G2-IU and updated them to the latest firmware of IPC_G3_EN_STD_5.5.160_210108. Having issues with setting up motion areas. I have an the DS-7608NI-K2/8P NVR running NVR_K51_BL_ML_STD_V4.30.060_201228. When I draw motion areas, I hit clear to remove the default 1 which is the whole area, click draw area and set my new area 1. This seems to work for a day then when I look the next day it has gone back to being the whole area again.
Is this a known issue or am I doing something wrong?
Also with privacy areas is it planned you can draw the area where you like similar to motion rather than squares? Not every helpful if your neighbours windows are not at perfect 90degree angles to you camera angle! Or is it possible to request features as I know motion areas where only squares before I updated the camera firmware.
Thanks for any advice!
