Hi
I went to a business park today, 4 x IP cameras connected to a PoE switch, 1 x cat 5 link from switch to NVR LAN port and 1 x cat 5 link from switch to 4G router.
Defaulted admin password no problems, upgraded the firmware of NVR and from then on it wouldn’t communicate to the cameras, these were not set as plug & play as they were connected to the switch.
I ended up defaulting the NVR but still the cameras would not communicate, in the end I had to plug the cameras into the NVR camera ports and link the LAN port to the 4G router bypassing the PoE switch completely.
Attached is the network setting page, did I set anything wrong?
The NVR takes an IP address and I think it distributes a separate IP address for the cameras via the NIC, I tried to apply these settings and it kept saying there was a conflict with the NIC but I’m not sure what’s wrong with it.
Apologies for the long post and thanks in advance
