Very strange. Firmware downgrade shouldn't be an issue but can be a bit labour intensive. I have my home cameras connected directly to the NVR ports but manually address them for my convenience. The issue with that is that if I downgrade the NVR firmware and it resets it default (which it did last time), it restores all channels to plug and play (from manual), which in turn readdresses all of the cameras which is a PITA.
I have the same NVR as you on 4.60.010 albeit with POE ports and I also have a spare 2347LSU/SL. When I get a moment, I'll add it to my recorder via the LAN and see if I can successfully get the push notifications, from that camera, through to my app via the NVRs connection to Hik-Connect. I'll post back the result.
