Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
What exactly is teams mode?With HikPartnerPro or HikConnect Teams mode.
With basic hik connect not at the moment , only Motion 2.0 area for certain models.
Ok. Thanks i'll give it a tryIts basicly HikPartner Pro options regarding device configuration transferred to hik connect.
Anyone can create Teams mode if you have normal mode. Just go under services and Create team. There are device number limitations tho.
You could look it like a platform for a bigger company, but private user can use it as wellOk
Do you know how can i delete the team a created? Because actually it is not so simple to use.Its basicly HikPartner Pro options regarding device configuration transferred to hik connect.
Yes i noticed that.Press 'Me' bottom right
Team information click on it
And at the bottom you have Disband team
Using team is better via web interface rather than over phone. Some things aren't meant to be configured over phone hence alot of companies do not invest a lot of effort to create it user friendly.
No i dont have that optionMy app is not on english, but once you click on team information you should have the button bellow:
I thing i have finished the team creation. Yes i am able to switch between personal device and team. It dosnt make any sense to be regional issue.Did you even finish the team mode creation? Are you able to switch between modes at the top left corner when on main dashboard?
Perhaps its not yet synced on server that you have created a team, maybe you just have to wait a bit before deleting. Or it could be regionwise options which works differently for me than for you
