Sorry for the delayed reply @mtv
Just to confirm, have you kept the NVR set to use the NTP server and set the cameras to manual in the time settings?
It's worth trying different NTP servers too in case the NVR is not connecting to it properly, just "pool.ntp.org" tends to work well wherever you are, or whichever the one for your country is here:
Changing the NVR's interval to 1440 minutes looks like it's helped other users with similar issues too (for whatever unknown reason):
Also, you shouldn't need to set up DST if using an NTP server, so try disabling this too in case this is causing the Hik-Connect time anomaly.
Hik-Connect may be holding onto the NVR's old time, so I would unbind and re-add it to your account too.
Which version of Hik-Connect are you using and on what platform?
pool.ntp.org: NTP Servers in Europe, europe.pool.ntp.org
www.ntppool.org
Yep the NVR NTP default is normally 60 minutes (which is bonkers), so I've set it to 1440 minutes (24hrs).
Here's why...
Looking at a camera NTP setting via the camera interface my defaults vary according to camera age.
The default for my older PTZ cameras is 60 minutes.
The default for smart cameras 2345 and 2387 is 1440 minutes.
The default time server on all my Hikvision & HiLook cameras is time.windows.com (though not my preferred server).
So me thinks why would they choose 1440 minutes instead of 60 on the newer cameras?
However the cameras are not set to use the direct NTP server feature by default, instead they are set to use the manual time sync.
All my camera time settings are set to manual time sync as supplied.
They are perfectly in step, identical time on all, so they must be using time sync sent from the NVR.
Since the default for the newest 2387 cameras is 1440 minutes then that tells me Hikvision are changing their thinking hence I'm going to continue using 1440 minutes for the NVR time interval. It makes no sense to set it more frequently than that.
Plus, the DST time settings on the NVR were incorrect after the 4.60 upgrade so I've set these correctly too.
(They were First Sunday and DST Bias 30min so changed to Last Sunday and DST Bias 60min).
My point to all this is...
That single change coincides with fixing the flickering image & date anomalies on my system, happy days!
