Harri Whipp
Administrator
This Tutorial is Out of Date
Please See the Tutorial Megathread for an Updated Guide
____________________________________________________________________
Firstly, ensure your camera is connected to the network and functioning correctly.Please See the Tutorial Megathread for an Updated Guide
Next go to http://www.hikvision.com.
Extract the file to a suitable location.
On this page select the ‘SADP’ icon.
EDIT: You may need to change the IP address of the camera to access it. To do this select the camera in SADP then on the left under modify parameters , change the IP address to one that suits you. Type your default password in and click save.
Default login is:
Username: admin
Password: 12345
You should now be able to view your camera.
Note: You may need to run plugins to view.
