Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Yer my cameras are all online. If I connect a monitor to the NVR I see live video. If I connect via IP I can see live video / playback video. The platform access part is the same apart from the server address but I’ve tried that. I guess I will need to contact support for this.
I’ve even tested pinging 8.8.8.8 on the NVR to prove my network is online and I got a good response. So I’m pretty certain my NVR is connected to network with interneYeah. Sounds lapp correctlyisnt configured ike the t.
Yes I lost my online connection. Everything else works fine but always see "offline" and cannot connect remotely. I think I read Hikvision stated you cannot downgrade. I ended up buying a new NVR. The new NVR has the v4.32.110. I've just replaced a camera and now see the green screen only on the android app playback.Did you have any problems downgrading?
@dazulrich - Thank you so much. That dreaded green box now is gone on my system after upgrade from V4.60.005_220806 to V4.61.025_220905_S3000451601v4.61.025 solved green screen for me. Got it from here
Resurfacing this, has anyone seen a fix that is iOS specific? I find everything works perfectly for Windows and Android so I assume the Camera and NVR setting is fine, and it is just an iOS bug??Hi all,
I bought a Hikvsion NVR (8MP POE) this week, I am fitting 4 new Colour Vu 8mp turrent and 4 standard Hikvison 8MP. I seem to have a problem and get a partial green screen on the standard Hikvision cameras when i switch on Hik Connect to HD mode from basic mode. Please note i am using an iPhone and an iPad.
Pictures attached
Any help appreciated.
There’s no known bug I’m aware of. Often there are more issues with unwanted image artefacts when stream encryption is enabled - I always have that turned off. Another option that’s easy to try in case it’s your device is to go to Me > Settings > Hardware Decoding Preferred and set it opposite to whatever it is now. That often helps with older iOS hardwareResurfacing this, has anyone seen a fix that is iOS specific? I find everything works perfectly for Windows and Android so I assume the Camera and NVR setting is fine, and it is just an iOS bug??
You're a genius, toggling the hardware decoding on the iOS device seems to have resolved the issue!There’s no known bug I’m aware of. Often there are more issues with unwanted image artefacts when stream encryption is enabled - I always have that turned off. Another option that’s easy to try in case it’s your device is to go to Me > Settings > Hardware Decoding Preferred and set it opposite to whatever it is now. That often helps with older iOS hardware
