I think this might be a firmware issue. I have the exact same issue, tried all the steps above. Used ClientDemo as well. When I select IPC/IPD CFG and select Device Server button, does come up with all the items. If I set SSH to Enable then click Set.
I simply get Save Failed.
Using Curl to try and PUT the SSH xml I get
XML:
<?xml version="1.0" encoding="UTF-8" ?>
<ResponseStatusversion="2.0"xmlns="http://www.hikvision.com/ver20/XMLSchema">
<requestURL>/ISAPI/System/Network/ssh</requestURL>
<statusCode>4</statusCode>
<statusString>Invalid Operation</statusString>
<subStatusCode>notSupport</subStatusCode>
</ResponseStatus>
Here is the thing - I don't think its not there I think:
- It's is not exposed due to
- We not using the correct user. There seems to be an engineering user (When I played around with ClientDemo in one of the tabs it returned Engineering User but can't remember now)
Even though when I try get the capabilities for the network SSH is not shown I still think this is because the auth we using for the PUT and Get is not allowed to view this.
For completeness here are my results as per this post:
- Firmware:
- Camera Type/Model: DS-2CD2T45FW
Network Capabilities:
XML:
<NetworkCapversion="2.0"xmlns="http://www.hikvision.com/ver20/XMLSchema">
<isSupportWireless>false</isSupportWireless>
<isSupportPPPoE>true</isSupportPPPoE>
<isSupportBond>false</isSupportBond>
<isSupport802_1x>true</isSupport802_1x>
<isSupportNtp>true</isSupportNtp>
<isSupportFtp>true</isSupportFtp>
<isSupportUpnp>true</isSupportUpnp>
<isSupportDdns>true</isSupportDdns>
<isSupportHttps>true</isSupportHttps>
<SnmpCap>
<isSupport>true</isSupport>
</SnmpCap>
<isSupportExtNetCfg>false</isSupportExtNetCfg>
<isSupportIPFilter>true</isSupportIPFilter>
<isSupportEZVIZ>true</isSupportEZVIZ>
<isSupportEhome>false</isSupportEhome>
<isSupportWirelessDial>false</isSupportWirelessDial>
<isSupportWirelessServer>false</isSupportWirelessServer>
<isSupportWPS>false</isSupportWPS>
<isWirelessMutexWithWirelessServer>false</isWirelessMutexWithWirelessServer>
<isSupportMACFilter>false</isSupportMACFilter>
<isSupportRFIDData>false</isSupportRFIDData>
<isSupportwifiProbeSSID>false</isSupportwifiProbeSSID>
<isSupportWifiProbe>false</isSupportWifiProbe>
<verificationCodemax="12"/>
<VerificationCodeModification>
<verificationCodeTypeopt="normal,empty">empty</verificationCodeType>
<isSupportDeclarationURL>true</isSupportDeclarationURL>
<supportPrivacyPolicyURL>true</supportPrivacyPolicyURL>
<verificationCodeModifyopt="true,false">false</verificationCodeModify>
<Hyperlinks>
<declarationURL>https://www.hik-connect.com/views/terms/termsofservice.html</declarationURL>
<privacyPolicyURL>https://www.hik-connect.com/views/terms/privacypolicy.html</privacyPolicyURL>
</Hyperlinks>
</VerificationCodeModification>
<isSupportIntegrate>true</isSupportIntegrate>
<isSupportPlatformAccess>true</isSupportPlatformAccess>
<isSupportGetLinkSocketIP>true</isSupportGetLinkSocketIP>
<isSupportWebSocket>true</isSupportWebSocket>
<isSupportWebSocketS>true</isSupportWebSocketS>
</NetworkCap>
IPfilter Settings (which correspond with the setting in the web interface)
XML:
<IPFilterversion="2.0"xmlns="http://www.hikvision.com/ver20/XMLSchema">
<enabled>false</enabled>
<permissionType>deny</permissionType>
<IPFilterAddressListsize="64"/>
</IPFilter>
I have tried with a linux machine and using Curl same results as above. I have also changed the XML schema to Hikvision just incase.
There must be some engineering username and password to enable this.
Is there any telnet host we can open this might help us poke around. Using ClientDemo and trying the telnet setting (Same place as SSH) same error occurs: Save Failed.
The post is excellent in terms of info so thank you for posting.
