Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
It's plugged direct to the NVR, if connected to another NVR, it functions perfectly well.Thanks @Leo2moro
Is the camera plugged into the NVRs PoE ports or a separate PoE injector/switch?
Is the camera new or one that you had before getting the NVR?
If it is a new camera, was the camera box sealed when you bought it or did you buy it 2nd hand from an Amazon/eBay seller?
The camera works perfectly when connected to other NVRs.Thanks @Leo2moro
Okay, if you had it already connected to another NVR it was probably activated with that NVRs activation password and this new 7616NI-E2 NVR does not recognise that password.
We would recommend trying a hard reset of the camera, you can do that by following the below instructions:
Disconnect the camera from the PoE
Remove the dome and locate the reset button (should be quite an obvious protruding button)
Press and hold the reset button
While holding the reset button, reconnect the camera to the PoE
Continue to hold the reset button for a further 30 seconds
Once 30 seconds have passed you can let go and the camera should reset & reboot, when it boots back up it should be activated with the NVRs password.
Yes, have tried other cameras and they too don't connect including brand new ones.Okay,
Have you tried connecting any other cameras to this port on the 7616NI-E2 NVR?
Have you tried the DS-2CD2120F-I camera on any of the other PoE ports on the 7616NI-E2 NVR?
All don't workHi @Leo2moro
So do no cameras work in any of the PoE ports on the 7616NI-E2 NVR or is it just the 1st port that doesn't work?
If all the ports are not accepting any cameras then I think it is likely that there is a hardware fault with the NVR and you will need to upgrade to a newer NVR model.
Is there no way to upgrade new version NVR firmware with this one?Hi @Leo2moro
