Recommended settings for a Hikvision Colorvu camera please?
Dave911
Hi, I have 3 DS-2CD2387GU cameras and I'm pleased with the picture overall but at night it becomes quite pixilated and faces are far from great.
What settings do you have your
-Resolution
-Bitrate Type
-Video Quality
-Frame Rate
-Video Encoding
I have a 10Tb hard drive so hopefully plenty of space.
Thanks.
Hi @Dave911 - sorry to keep you waiting on a response.
Please see some recommended settings below, but I would also log into the camera and play around with the Image>Display Settings at night if those don't help.
The ones to focus on are shutter speed (in exposure settings) and digital noise reduction (in image enhancement).
  • Resolution: The highest available
  • Bitrate Type: Variable
  • Video Quality: Medium or Higher (people like to use Highest too, but you'll need to have plenty of bandwidth available.
  • Frame Rate: A minimum of 15fps to maintain a smooth video, most use >20fps.
  • Video Encoding: Based on the issues you're describing with the video, I would try H.265 first, then H.264+ or H.264 if you're still having issues.
These threads should also be helpful too:
