Hi everyone. I have a situation where I need an IP camera to monitor a path at the side of my house.
There is no place to mount a camera other than high up on the building its self.
This will mean screwing a camera onto the wall and pointing it down to monitor the path that runs along tight to this building.
I currently have a Hikvision camera and NVR, so would like to stick to a camera that will work with this brand.
My main concern is that pointing a camera towards the ground is are these bullet cameras waterproof enough to do so.
The building / path is 8mtrs long, and I can mount the camera at a height of 4 meters,
this would keep the camera below the floodlight that is higher up on the apex of the building.
Will this light cause trouble with the camera with it being above the light, sadly this is the gable end of a house and if I have to put the camera to either side of the light then it will also have to go lower down as the gable is wider lower down.
I do not want to use a 2.8mm lens as the distortion I do not like on the one I have, Would 4mm be too narrow to cover 8mtrs wide at 4 meters height.
Any comments or advise more than welcome, thanks.
