Okay, thanks, that's excellent. One other question regarding the HiKVision IP cameras. Is it possible to stream them live online?It depends, if the POE injector conforms to the IEEE 802.3 POE standards, then all should be fine.
Ubiqiti were notorious for early POE devices that did not conform to the POE standards and therefore did not work as expected.
Here is a basic standards conformant POE injector:
Tenda PoE15F 10/100Mbps PoE Injector
The Tenda PoE15F PoE injector delivers power and data through one Ethernet cable for easy installation and network extension. This unit's PoE port delivers power up to 100m and is compatible with IEEE802.3af/at compliant powered devices.www.use-ip.co.uk
Yes, I'm using a company called Cam Secure who will host the camera. I've also got a subscription with no IP so I can create a DD NS address as well. Basically, I want to use one of my bullet cameras to film the badgers in my back garden. It would be good to stream them online for everybody to watch. But I just want to make sure that these Hikvision cameras are capable of doing the job.Typically you would need a third-party service to stream a Hikvision IP camera live online.
