My kit finally arrived and I have the system installed and been playing around with it for past few days. Mostly impressed, and I'm glad I went for the ColorVu cameras. The nighttime image is great, compared to IR black & white for residential property.
Anyways I've figured most things but have some questions. Any help/recommendation/resources would be appreciated.
DS-7608NI-I2 + ColorVu (plug and play install)
- Any guides or recommendations for encoding parameters? Video quality: higher vs highest? What frame rate should be minimum? Currently running full frame rate which to me is excessive. Have a good size disk. Waiting to see how many days this will give me. What max bitrate to use? Is it autoset? Half the cameras have one value, the other half a second value?
- What is the Picture menu in the nvr used for? Same question for Application menu?
- Does above nvr support motion detection highlighting in the playback timeline? I was always impressed with an old system I used before, which would analyse the footage and overlay a graph to show lengths of the playbook footage where activity was occurring. Does this nvr support anything similar? If so, how is it viewable, in the nvr web browser, or using ivms4200 or only at the nvr locally?
- Same question above, but this time instead of highlighting when playback footage has motion, can the nvr overlay when smart events were triggered?
- I have HikConnect setup and working fine. Is it possible to disable smart events from being triggered with a single button from the app? i,e. not to stop app notifications but just to let the NVR know, I am now home, I don't need any intrusion detection till I leave again?
- Would be great if 5 was possible and even better, with geolocation. So when the app detects I've left home it enables smart events
- Finally, already getting lots of false alerts for intrusion detection, even with ROI defined and min object size drawn. I think spider webs is going to be an issue. What is best home solution? Spider repellent off ebay?
