Firmware M-Series Firmware v5.03 Released
Another very minor release by the looks of it. I wonder if we'll ever see the AcuSearch functions supported on this recorder...
Currently it's only available on the global product page but not the firmware searches or UK product page.
I was hoping this release would support the DS-KV6113-WPE1 fully...
It was the issues described at the beginning of this thread...
I had a look, I've not had that problem unless I'm missing something (I possibly am). I think mine was added first as an Access Control Device, then it's working as normal for Video; it didn't need to be added using RTSP protocol, it shows Hikvision and TCP.
Do they ever provide release notes? I see they put 'For better user experience, we highly recommend you to update your device to the latest firmware asap.'
Presume they want us to be Alpha testers for the update...
I can only add the doorbell using RTSP. The standard HikVision protocol results in a Device Type Mismatch error :(
FYI, I installed the latest version available in Australia (v5.03.000_240814) and seems to be working all fine. It’s also fixed the missing preview photos on event notification clips on the HikConnect app on my iPhone.
FWIW, I suspect this occurred prior to v5.03.010, BUT it caught my attention today. For me,
EVENT MARKERS in PLAYBACK are off by an hour (i.e. event markers are +1 hour from actual)
For example:
  • via WEB UI
  • go to Live View.... all Live View time stamps show the correct DST times
  • go to Playback
  • enter a Search for Perimeter Protection --> Intrusion Detection
    • use today's date and hours 00:00 - 24:00
  • Current real time is 09:18:40
  • Search results:
    • Event Marker shows at 09:46 (aka the little "red" vertical bar)
    • unable to play this event, since it is in the future
  • manually move the playback to 8:46
    • and there is the recording that (I assume) generated the event
This is repeatable. Should I repeat the sequence using a previous day.... the little "red" vertical bars are +1 hour from actual time.
My high level conclusion.... time stamps on recordings look correct, just the Markers are off.
My test environment:
  • DS-7616NI-M2 @ V5.03.010 build 240606
  • DS-2CD2387G2H-LISU/SL @ V5.7.15 build 240201
  • Chrome browser using the Web UI on the NVR
  • devices connected via CISCO POE switch
  • NVR & Camera clocks are sync'd to a CISCO Time Server, all on the same VLAN
  • actual time differences between devices < 1 sec (probably < 500ms but my available tools don't give me that granularity)
  • actual time difference between CISCO Time Server and real time, < 1 sec
  • NVR / Cameras have DST set with DST Bias of 60 minutes
  • SSH command --> getDateInfo <-- run on NVR & Cameras show a respectable / correct time. (e.g. Sun Jun 16 09:18:40 UTC 2024)
FWIW, back in June 2024, I complained about the Playback "Event Markers" being off by an hour.
Now that I am off Daylight Savings Time & back on Standard Time, the new Event Markers are no longer off by that 1 hour (aka DST Bias).
Just a heads up to HIK Development..... you still need to fix this.
