Hikvision has released new firmware for their G5 Series IP cameras. The latest firmware, Version 5.7.3, can be downloaded here.
NB - you may need to refresh your browser when viewing the Hikvision portal to see the newly added version at the bottom of the list.
We don't currently have full release notes for this firmware but will update this post if/when they are available.
Hikvision Support has told us that the primary function of this update is to fix the below issue:
"On Hik-Connect, when you add the newer device models, there should be a bell on the side that activates/deactivates the One Key Do Not Disturb function. On previous G5 firmware, this was unavailable. This new V5.7.3 has added that button on Hik-Connect for the G5 cameras."
