Update 25th February 2020 - Superseded by V5.6.4: Latest HikVision Firmware for G1 Series cameras - version V5.6.4
Hikvision have released V5.5.60 for their G1 series IP CCTV cameras
You can download the firmware from here.
It's not available from their European portal yet, but should appear here in due course.
In the absence of full release notes, please check our post here to confirm whether your camera uses Hikvision's G1 firmware.
Software Description:
Hikvision Firmware V5.5.60 Features
*for G1(DS-2CD3XX5, DS-2CD3XX3) Cameras
1. New Features
l New 2MP models of 3 series are released:
DS-2CD3025G0-I (Sample), DS-2CD3023G0-I (Sample), DS-2CD3125G0-I (Sample), DS-2CD3123G0-I(S) (Sample), DS-2CD3325G0-I (Sample), DS-2CD3323G0-I (Sample), DS-2CD3525G0-IS (Sample), DS-2CD3523G0-IS (Sample), DS-2CD3T25G0-I (Sample), DS-2CD3T23G0-I5/I8 (Sample), DS-2CD3625G0-IZS (Sample), DS-2CD3623G0-IZS (Sample), DS-2CD3725G0-IZS (Sample), DS-2CD3723G0-IZS (Sample), DS-2CD3H25G0-IZS (Sample), DS-2CD3H23G0-IZS (Sample).
l New 4MP models of 3 series are released:
DS-2CD3045G0-I (Sample), DS-2CD3043G0-I (Sample), DS-2CD3145G0-I (Sample), DS-2CD3143G0-I(S) (Sample), DS-2CD3345G0-I (Sample), DS-2CD3343G0-I (Sample), DS-2CD3545G0-IS (Sample), DS-2CD3543G0-IS (Sample), DS-2CD3T45G0-I (Sample), DS-2CD3T43G0-I5/I8 (Sample), DS-2CD3645G0-IZS (Sample), DS-2CD3643G0-IZS (Sample), DS-2CD3745G0-IZS (Sample), DS-2CD3743G0-IZS (Sample), DS-2CD3H45G0-IZS (Sample), DS-2CD3H43G0-IZS (Sample).
l New 6MP models of 3 series are released:
DS-2CD3163G0-I(S) (Sample), DS-2CD3363G0-I (Sample), DS-2CD3563G0-IS (Sample), DS-2CD3T63G0-I5/I8 (Sample), DS-2CD3663G0-IZS (Sample), DS-2CD3763G0-IZS (Sample), DS-2CD3H63G0-IZS (Sample).
l New 8MP models of 3 series are released:
DS-2CD3085G0-I (Sample), DS-2CD3083G0-I (Sample), DS-2CD3185G0-I (Sample), DS-2CD3183G0-I(S) (Sample), DS-2CD3383G0-I (Sample), DS-2CD3T83G0-I5/I8 (Sample).
l Support CC Certification.
Notice:
1. Support HTTPS Browsing which is disabled by default.
2. The password cannot contain the username.
3. Device lock logs can be saved and searched.
l Support 31 languages in web browser.
l Optimize unattended baggage detection and object removal detection, and sensitivity is available.
l HLC function is available.
2. Improved Features
l Support Focus zoom on the Hik-Connect Client.
l By default, the percentage of picture is changed from 25% to 5%, and the record is changed from 75% to 95%.
l The prompt “Device error” on the web browser is replaced by “insufficient performance” when the device performance is insufficient.
l The issue that device restart occasionally is fixed.
3. Leftover Issues
l The purple edge is obvious in live preview for 3X43G0 models.
l When the password contains a username, the device cannot to activated on the Hik-Connect and IVMS-4500 Client.
l The issue that the device failed to login when the password contains special characters “Æ”, “Ø” or “Å” will be fixed in the next version.
l For 3X45G0 models in 2688*1520 resolution, the privacy mask area is offset and the offset position is gray.
l Web browser shows different from Hik-Connect Client when the time zone is UTC + 14:00.
l For 3XX5G0 and 3XX3G0 models, the remote configuration interface failed to open on the IVMS-4200 Client when HTTPS and HTTPS Browsing were enabled.
l The position of the rules changed when mirror or rotate is enabled.
Compatibility Update
l HIKCGI version: V2.0;
l ISAPI version: V2.4;
l ONVIF version: V1612, official test tool version: V1701;
l Milestone:
1. Milestone Enterprise 8.1a(10.2a), Milestone drive version (Driver 9.1), test HIKCGI
2. Milestone software version (Milestone Corporate 11.1a), Milestone drive version (Driver 9.1), test HIKCGI
l Avigilon:
1. Control Center: V6.6.2.4
2. Test ONVIF.
l Excaqvision:
1. Version: 9.0.3 124768
2. Protocol: HIKCGI, ONVIF
l Intellect: V4.10.3
l Digifort: V7.2
l Axxon: AxxonNext-4.0.2.5237
l NAS(Only test for Brainaire):
DS-A2016R, DS-A1016RS V2.2.0-7
l Tested NVRs:
DS-96256NI-I24/H(baseline V3.2.8_170213_05)
96000 I Series
96000NI-I Series NVR (V3.6.21)
Skylake Series: DS-96256NI-I24(V3.6.22)
E Series: DS-7732NI -E4/16P(V3.4.98)
G Series: DS-7608NI-G2/4P(V3.4.1 build 151225)
K Series: V3.4.92
I Series: DS-8664NI-I8(V4.1.50)
Netra DVR: DS-9016HFI-ST(V3.4.3)
Note: The compatibility of IPC and NVR models in the same NVR series is the same.
l Tested Keyboard:
DS-1600KI V2.0.0
DS-1006KI V1.0
1. New Features
Notice:
3. Leftover Issues
l Milestone:
l Avigilon:
2. Test ONVIF.
l Excaqvision:
l Digifort: V7.2
l Tested NVRs:
96000 I Series
K Series: V3.4.92
l Tested Keyboard:
DS-1600KI V2.0.0
DS-1006KI V1.0
