J John Carr Member Messages 11 Points 1 Jun 2, 2017 #1 Hi all, can anyone tell me, can an ip camera be connected directly to a Pc without a router or switch and if so how is it done ??? Last edited: Jun 2, 2017
Phil Administrator Staff member Messages 5,189 Points 113 Jun 6, 2017 #2 You need to fix the IP addresses of both your PC and the camera so that they are both in the same domain range e.g. Laptop / PC at 192.168.1.1 Camera at 192.168.1.2 Both set at the same subnet e.g. 255.255.255.0 How to Assign a Static IP Address in Windows 7, 8, 10, XP, or Vista
J John Carr Member Messages 11 Points 1 Jun 9, 2017 Thread starter #3 Will I need a crossover cable or will the gigabit connection auto crossover ?
Phil Administrator Staff member Messages 5,189 Points 113 Jun 9, 2017 #4 I think you will need a crossover cable for a direct connection (PC to camera)
L Leonard Curry New Member Messages 3 Points 1 Jun 10, 2017 #5 if you are using a power injector the cable going from the PC to the power injector is going to have to be a crossover cable.
