Intercom app from indoor station
arturoRtt
Hi there,
I've doing my research and I realized that indoor stations are Android tablets with an APK installed ( among others) called Intercom.
Has anybody extracted this APK from the indoor station?
Thank you all.
Hi there,
Thank you all.
I did on non b revision is past when it was android 5. Didnt bother with new 1 (B) . Once i rooted it. I didnt have knowledge to revert back to how it was. So i didnt rly go for b revision.
App worked great on phone. Still if ever extract it(easy part) signing will give you headache
But i made myself an app that use hik sdk so i dont need their apk anymore
Hi, thank you for your reply.
I have a client who has an intercom but not an indoor station. He is using it through SIP with a soft client in his phone. However lately he has been experiencing some issues. So I though about analyzing the "native" solution from Hikvision (the APK), but I can't find it anywhere. Do you still have it?
So your app works like the built in solution from Hikvision in the indoor stations?
Thank you very much for your answer.
It uses the same funcrions as its built by hikvision sdk yes.
Hello,
I searched and I found SDK for Windows and Linux. For Android it is required to contact "integration technical". Where did you get it? Do you know how to contact? I can't find any mail or contact form.
I work for natuonal distributer. Cant rly tell how it workd for end users
You could make it with linux sdk, use rapi as proxy api sdk server, and flutter as front
Hey I took your advice and I am trying linux sdk. What language are you using? I'm using the java example to get an idea of how to deal with the thing However out of the box with this example, the only thing it seems to work is the login part, I can login to the intercom but nothing else, no preview no sound no voice talking. Nothing. And there are no errors in the log. So I don't know how to continue, any advice?
