HikVision have just released new V5.5.2 version firmware for their G1 Platform / EasyIP 3.0 range of cameras.
When you select this firmware you are currently given a choice to select STD or NEU versions of the software.
STD = Standard
NEU = Neutral
And, at the moment, I can't work out what the difference is
I've installed each, and played spot the difference.
(a Google search turned-up mention of no branding in the neutral version - it's not that. Both versions are HikVision branded)
If you work it out, let us know - Thanks.
STD = Standard
NEU = Neutral
