On Hikvision NVRs (such as DS-7608NI-K2-8P) , do all the cameras have to connect directly to the PoE ports on the NVR, or can the cameras be connected to a PoE switch elsewhere and then just a single Ethernet cable connect the NVR to the switch, and PoE disabled on the NVR?
I'm planning a system at the moment, and the choice of site for the NVR to be secure and to mask the noise of the fan (which I read is quite loud), it won't be possible to run all the cables from each camera to the location, but it'll be possible to network 4 or 5 of the cameras to a PoE switch in a different central location and then run a single Ethernet cable from the switch to the NVR.
Thanks![Smile :) :)](/forum/styles/default/xenforo/smilies/smile.png)
