I am looking to replace an old CCTV installation in a charity I volunteer for and would like some advice/confirmation on my plans please.
The attached plan shows the proposed positions and some measurements. Our existing cameras are in positions A and B
All cameras will be mounted around 2m off the ground, there is no option to mount higher.
They will also be wall mounted
For the cameras I am basing the FOV as follows, this looks to be close enough to the various cameras specs
Positions 1,2,3 are indoor, florescent lighting, will always be lit so night/dark viewing not important
1) Type: Turret, 4mm
Use: General coverage of our scooter storage area
Record clear images of equipment going in and out in case of any damage claims.
2) Type: Turret, 4mm
3) Type: Turret, 4mm
Use: General coverage of our reception area
4) Type: Turret, 6mm, - color-vu? but would have to be 4mm
Use: Provide clear images of people faces when viewed on a real time screen for our reception desk staff to see
clearly who is there and what is going on. This enables them to operate the barrier control effectively.
Environment: Under cover with some average lighting but sometimes bright sunshine will provide plenty of light.
Some dusk and night time operation when its dark early in the evening.
Camera to be mounted internally looking through the window
IR will probably need to be turned off due to reflection.
This is to stop tampering and to help keep lens clean
May need to create a surround to reduce reflections on the glass.
5) Type: Dome, 2.8mm
Use: Provide general view of the car park area and of people in the corridor. This will have a live view on our reception.
To enable monitoring of our customers in the car park and also our scooter entrance.
Environment: Under cover with average lighting 24 hours a day.
Due to the wall there will be an obscured area shown in red on the plan, this is acceptable.
I am looking at the Hikvision range of 4k cameras paired with the Hikvision DS-7608NI-M2/8P 8-channel 8K M-Series Network Video Recorder NVR
Proposed cameras
Position 1,2,3 - 4mm turret, DS-2CD2386G2-I
Position 4 - 6mm turret, DS-2CD2386G2-I
Position 5 - 2.8mm Dome, DS-2CD2186G2-I
Storage
We are looking at 30 days storage using H265+
3 cameras will run for around 9 hours a day, 6 days a week - medium activity + movement outside these hours
2 cameras will run 24h - 12h of medium activity and 12h of low activity
what capacity would you recommend for this?
My questions:
Thanks for your help
Trevor
- 2.8mm or 108º
- 4mm or 88º
- 6mm or 53º
Proposed cameras
Storage
My questions:
- As the cameras 1,2,3 will be positioned so that the current lighting is in the top of their FOV, any suggestions to reduce glare/compromised image quality.
- Any alternative suggestions for camera locations
- Are the FOV proposals good or could they be improved
- What models of camera would you recommend, I had considered colorvu for position 4 but they don't make a 6mm version.
having said that with darkfighter keeping the colour image for even relatively gloomy light levels colorvu may not be that beneficial. - Any other design/implementation suggestions to get the best out of the installation.
- We will need real time view of cameras 4 & 5 via a PC, any potential issues that I could encounter?
- Recommended disk capacity?
Trevor
