HELP IP address changing after about 24 hours
Jmc56
I am working with a DVR that is older than Moses. The model number is dvr8050ndvd and if you find anything other than a spec sheet good luck. The unit worked 3 weeks ago when it no longer connected to the network. I checked the ip address and it had changed. We had planned an upgrade to the local network so we added a static ip address 71.118.48.180 with the proper subnets and turned off DHCP. This worked for about 24 hours. The next day the ip had changed to 192.168.1.1 (subnet and gateway also changed, each time it changes it is different) and the cameras were no longer accessible. The DVR is not locking up as the front panel switches allow you get right in and change the ip back and all works for about 24 hours. This happens almost 24 hours later almost to the minute. The owner accesses the cameras through a free program called Netguard on an Iphone I also set my Android to use the same software. The application really only allows you to see the camera feed not do anything else. The cameras still show on the in-house monitor and are recording properly. The unit is connected through Ethernet to a gigabit switch direct to the ISP modem. The network is working fine as we have about 300 devices on this net.
Looks like the IP address you set is an internet IP address?
Normally you'd fix it to a static IP address within your domain range; the same range managed by your router.
