I just installed a new system for a customer on Friday. Latest firmware was installed prior to installation/configuration - 4.30.061. This has a couple of issues that need resolving. The system I installed was just three 4MP AcuSense (2346G2-IU)
Live view on local monitor stream switch. Many moons ago you could set up each window division of a live screen view as Sub Stream, Main Stream or Auto. It would work as follows:
- Set to sub stream it would keep showing the sub stream whether in multiscreen or when double clicked to maximise
- Set to main stream it would keep showing the main stream whether in multiscreen or when double clicked to maximise
- Set to Auto it would display the sub stream when in multiscreen view but automatically change to main stream when maximised with a double click and revert back to sub stream when returning to multiscreen.
The option to set to have the choice like above was removed long ago and since then Auto is how it is set.
Unfortunately this does not work on 4.30.061. In a 4 x 4 split - all 4 window divisions were set to show the sub stream
- when you double click to maximise it switches to main stream (as it should)
- when you double click again to return to multiscreen, the other cameras go into "No Resource" for a few seconds
- When it settles and all images are displayed - 2 of the 3 cameras are showing the main stream instead of sub stream.
This happens every time you double click a window division then return to the 4 x 4 multiscreen with another double click. Awful.
Password Change Prompt. Set up a user account while logged in as Admin for the end user with a password of their choice. Every time they login now, they're prompted to change the password. It's obviously this way by design but completely unnecessary and means to get rid of the annoying prompt they need to change from the password they've chosen initially.
Event Playback to Normal Playback Switch. When viewing Event Playback/Smart playback it's simple to skip the unrelated video, jumping between events. When something of interest appears during Smart Playback - you could click on to Normal Playback. This continues playback at the same point (or used to) without interruption, and without jumping to the next event. When you're done, you could click Event Playback again and it would resume at the same point and skip unrelated video to the next event. In 4.30.061 if you're viewing in Event Playback mode, spot something of interest, and want to view it continuously - clicking Normal Playback will start the camera playing back from midnight or the first recording on the selected day. So you have to manually navigate the timeline to find the event.
