Door Entry DS-KV6113-WPE1(B) vs DS-KV6113-WPE1(C)?
balimelon
Dear All,
I have had a HikVision DS-KV6113-WPE1(B) doorbell for a few years. It still works and I am quite happy with it. However, I am thinking about the possibility to upgrade to the newest (C) version. The older one is starting to do weird things occasionally. Not a big deal though because it doesn't happen frequently, but I'd rather to change it just in case. The reason for choosing the same model is because it will fit in the current plate holder (you can see it in my profile pic).
Does anyone know whether there is any noticeable difference between both models or are they the same from an operational point of view?
Any hardware upgrade which makes the doorbell to work more stable, fluent, better picture or anything?
I guess the SD card slot has not any function still, right?
Cheers!
Only a few:
C version support connects mechanical doorbell, this is the only hardware change
Support AP mode
You can install the latest firmware with the C version, for the best compatibility and stability
