Double images in all cameras? Ghosting?
BTW, we did this work with my brother in law. If you are guessing that, maybe is the reason of all my problems :D hahah. In fact, I didn't know about NVR solutions. I would've chosen that solution instead DVR. :(. Now it's too late.
But when the light is on, the image is really bad. I can guess is because increase on amps demanding.
Does it mean that the power supply doesn't have enough amps?
No not necessarily. It's more that the cameras are sharing a PSU when Hikvision may recommend one adaptor per camera. I had a similar situation on a job a number of years ago and wasted time installing bigger supplies rather than additional supplies. To fix it you can either use a 12V 1Amp plug in adapter per camera or a PSU that provides separate outputs for each camera.
