RamblinMan
- Thread starter
- #21
Take note of which Display Port you are connected to [VGA or HDMI]
Access the NVR GUI via Web Browser & in the Configuration tab, navigate to System > System Settings > Menu Output
this is where you can change the Resolution Output to suit your Monitor for either VGA or HDMI
The Menu Output dropdown options, if you choose HDMI then your mouse/menus will only be available on the Screen connected to HDMI [Same for VGA etc] best option choose AUTO
Now to rectify the Display Issue where you can Not See all the Menu Items ................................... is done by your Monitor/TV settings [NOT the NVR], usually toggling through the Monitor/TV Picture or Aspect Ratio settings will identify the one you need, something like Scan or Full is usually the correct setting
Hope this helps
Gary
Thanks for the info. I think why this would not show for us on the 4k tv is because it was selected to VGA although for the whole time we've owned the system it had been connected by HDMI.
I did change it back to Auto.
For some reason, our TV monitor that we have had attached to the NVR will not let us change the aspect ratio. Doesn't even show any options when it is connected to the NVR. If we connect it to another source, we get 4 or 5 options. As soon as we connect it to the NVR, the only option is "Full." We had been playing around with this and the resolutions when all this started. Now that I have access through the Web, I'll try to change it that way to see if it will do anything.
I know the contractor that installed it quickly found a way to show all of the menu items. Got back in touch with the company and the particular vendor is gone and they were of no help. I'll play around more with it.
Thanks so much for the response.
