I know that this has been discussed elsewhere on the site but I thought I'd have a rant about a conversation I've just had with my supplier.
Start Rant
The current DS-2CD2347G2 cameras that run on G3 platform firmware are not receiving further firmware updates from Hikvision. They have been superseded by a C revision model that uses G5 platform firmware. That fact is noted on a Hikvision spreadsheet on their website. There's also some information regarding the benefits and operational differences between a model running G3 and one running G5 platform firmware in another document.
I need around 10 for an upgrade I'm doing. As it's not clear what my supplier is offering I contacted their technical support department with my query. It went a little like this:
"I understand there's a new hardware revision - will I receive the old G3 platform camera or the new G3 platform camera when I place my order"
Response - "we can't say - you could get either depending on what we have in stock/have been sent by Hikvision"
"I don't want to place an order unless I'm ordering the new model. Why would I want to buy something new that is considered end of line and will not receive further updates"
Response - "Understood but the part number is the same and the revision is not marked on the box, so we don't know whether it's the new one or not"
"Even if the revision isn't indicated on the box, the firmware version loaded by Hikvision is. As they use different firmware and the G5 is only up to to 5.5.114 whereas the G3 is at 5.5.160, it should be crystal clear which version is in the box without breaking the security seal or powering it up"
Response - "We can't say for sure what you'll receive, we always order the latest from Hikvision but may still have stock of the old model"
Bearing in mind that I can return an order unused for a full refund it seems a little ridiculous that I could order them, read the label on the box and return them immediately for a refund if they're not the new model then repeat that process ad infinitum until I get what I want.
End Rant
Start Rant
End Rant
