Hi everyone,
I have cracked on with installing my CCTV, I have run a few cat 5 cables and tested them successfully using my Haydon tester. Unfortunately after running a length through some conduit I have found that my tester is flashing both pins 1 & 2 simultaneously and then cycling through the other pins correctly at one end, the other end flashes fine.
Will I have to replace the whole cable or will my Hikvision turret camera be ok with the 1 & 2 pins, I guess crossed? I am unsure if the camera uses those pins?
I have replaced both ends and redone the connection but it has not fixed the problem.
Thanks for any help
Regards
Jim
Thanks for any help
Regards
Jim
