Hey,
how does it work via android app when everything else doesn't - the app must use some other protocol ...
it's very strange, but my camera hangs every now and then and needs to be rebooted. I didn't buy the camera here nor do I use HikVision NVR but google did bring me here as it most populated forum for HikVision ...
anyway. I am looking for self hosted NVR, i tried Shinobi, Frigate, iSpy and some others ...They all connect via RTSP feed and use ONVIF.
works ok i suppose, for a while at least. then at some point, camera stops streaming RTSP feed and you cannot probe it via ONVIF either, just doesn't find it... after reboot everything is back to normal but just for a little while.
Naturally i would upgrade firmware first, but android application doesn't find any updates ... network issue try again later, every time.... can't ping home i suppose, china too far.
I tried searching for firmware here https://www.hikvision.com/en/support/download/firmware/ but i don't know which one i have ... any ideas how to check?
some information i was able to retrieve with ONVIF Device manager
Manufacturer: H264 - how is this manufactur? this is codec and even this wrong output stream is in h265 ... i know because Frigate won't play it in firefox.
Model: IPC_NT98566_N8_-WQ_S38
Hardware: 00001
Firmare: V5.00.R02.000639IO.10010.140217..ONVIF 16.12
I don't know which one of these tell me anything, but FW v 5.00 is quite old i think .. i've seen 5.5 floating around but again, how to find the correct one??
AND can i even upgrade manually? via SD card, or how do you even do this?
many thanks guys
edit: it's this 8MP camera, but it doesn't say anything of value there: 33.74£ 22% OFF|5mp Outdoor Ptz Wifi Ip Camera Icsee 3mp Hd Cctv Security Camera H.265 Ai Auto Tracking Wireless Surveillance Camera Support P2p - Ip Camera - AliExpress
i don't even know if it's 8, 5 or 3 MP LOL - it says all of those in the title.
Hardware: 00001
many thanks guys
