Building a Reliable Parallel System for Smart Event Handling with Hikvision Cameras: Seeking Platform & Hardware Recommendations
rajiv.dey.se
Current Setup:
- Cameras:
- Hikvision DS-2CD3T56G2-ISU/SL (Lens: 2.8 mm) - 2 pieces
- Hikvision DS-2CD3356G2-ISU/SL (Lens: 2.8 mm) - 4 pieces
- NVR:
- Hikvision DS-7608NI-I2/8P - 1 piece with an 8TB disk
Problem:
The current setup is working fine in terms of recording. However, the smart events generate a lot of false positives, making it unreliable for automating tasks like switching on lights upon human arrival in specific regions.
Objective:
Build a parallel system that relies on camera feeds directly from the camera or the Hikvision NVR (RSTP) to accomplish the following:
1. Trigger Smart Events:
- Detect motion and human presence, sending triggers to Home Assistant via MQTT. (Note: I have a parallel home automation platform with Home Assistant as primary and Habitat as a failover).
2. Audio Alerts:
- Play voice notifications on Alexa devices based on smart events.
3. Remote Monitoring:
- Pop-up video or images on a remote client via VPN. The client software should be part of the platform, such as Blue Iris, a Scripted NVR, or Frigate.
4. Remote Configuration:
- Allow remote configuration of smart events through VPN (VPN setup already in place).
5. No Recording Required:
- The Hikvision NVR will handle recording, so this new parallel system is an addition, not a replacement.
6. Live Feed Viewing:
- Provide the ability to remotely view live camera feeds.
7. Email Notifications:
- Send email alerts based on smart events.
8. Smart Event Logging:
- Maintain a detailed log of smart events with timestamps, including the ability to export or review logs remotely.
9. Enhanced AI Detection:
- Use AI-based detection to reduce false positives by distinguishing between different objects, like humans, animals, and vehicles.
10. Alexa Integration:
  • Display the camera feed on Alexa Echo Show devices using the Monocle skill, triggered only when specific events occur.
Request for Advice:
I would appreciate any recommendations on the most suitable platform to achieve this, along with the recommended hardware to run it. My priorities are reliability, accuracy, and a reasonable budget. Thanks in advance!
Before jumping in the customised solution, could you share how you calibrated your intrusion detection?
It might be its just badly calibrated and all this can be avoided doing a proper configuration on cameras.
Would you mind sharing screenshot with rules from one of your cameras? Then we could discuss changes if something is wrong.
Cheers
Just for a refference, i have DS-2CD2387G2H-LIU 2,8mm at home, and haven't had a single false alarm with my configuration. I do have dog which is excluded from triggering. It does trigger only when i leave and enter the house at certain hours.
