Accusense DS-7608NXI-K2 not supporting Video Intercom Indoor and Outdoor stations and what is DS-KV6113WPE1(A) number of video streams
alfaclvi
Gives a lot of help
Issue 1:
Both DS-KV6113WPE1(A) and DS-KH8301WT are recognized as Device Access Switch when added manually on NXI-K2 Accusense NVR.
But there is no option to be recognized as Video Intercom stations, although both are supposed to be a kind of Access Control Devices.
This should be convenient for not adding both NVR and Indoor Station on Hik-connect but only NVR.
Issue 2
DS-KV6113WPE1(A) can be added as Camera on NVR by using HIKVISION Protocol port 8000 or HIKVISION RTSP Protocol port 554, allowing recording and viewing on Hikconnect.
DS-KH8301WT support Platform Access giving push notifications on Hik-Connect app when used in combination with DS-KV6113WPE1.
But when KV6113 is added either HIKVISION or HIKVISION RTSP on NVR, then Hik-Connect picture on call is blank loading until 55%. Indoor Station picture is OK.
This means that when not at home, I receice the call but I cannot see on Hik-connect who is the caller. Only by cancelling the call and look on NVR image of KV6113 camera.
If I delete KV6113 from NVR, then caller image shows on both Indoor Station and Hik-Connect.
Issue remains the same if on NVR Live View settings the KV6113 image is disabled.
Issue remains the same if on Hik-Connect NVR settings-Camera Management the KV6113 is set to OFF.
Does this mean that the (A) model of KV6113 supports only 2 video streams?
Does the new (C) model of KV6113 support up to 6 video streams as mentioned on 6 Series Villa Door Stations Version: V2.2.55_build220419 Release Note(2021-04-19)?
Is this a matter of streams or number of users?
