Zero channel permission
dyna
Hello,
I have a DS-7732NI-I4 / 24P.
Is zero channel only available to admin? It won't work for any other users I setup.
I want to setup a user so that they can basically only watch that channel because I can control the bandwidth via the zero channel encoder settings.
Thanks.
Hello,
Thanks.
We have spoken with Hikvision technical support and they say that what you are trying to achieve with Channel-Zero encoding is not possible with Hikvision equipment.
Dan,
I appreciate your taking the time to contact them. That was extremely kind.
I am a little disappointed with the actual answer though. To me, it seems like the zero channel's primary goal is to have a bandwidth controllable view. To limit that only to the admin seems like a waste.
The NVR is on cellular data but not unlimited. I will start another thread about this.
Thank you again
Dan,
Thank you again
I asked them to clarify their response and this is what they came back to me with:
According to the customer description, I think the customer requirement is to let the user only watch the channel zero.
We can setup the channel zero on the user account , however we can’t limit the user only watch channel zero
So it is possible to set up Zero-channel for other users you just can't have it be 'view only'
