Which hikvision ptz camera?
Ltec
What ptz camera that you sell would you recommend as a calving camera?
It is a 15m shed by 6m
It will be exposed to the weather as its an open shed and will be used day and night. I need to zoom in on the animals to check on them.
I have a point to point going to the shed for connection.
There is just so many ptz cameras.
Audio would be good but not a necessity.
Hi @Ltec
The Hikvision 4" DS-2DE4425IW-DE(S5) is one of Hikvision's most affordable PTZ cameras and should offer all of the features you need. I should point out that it does not offer auto-tracking - you would need to be looking at a more expensive model if this is a requirement. It's key features are:
  • A 100m IR range, so it can generate a black and white nighttime image up to this distance. Stronger IRs are available on other models if it is required.
  • 4MP resolution / 25 FPS, meaning it offers good video / picture quality.
  • A 25x motorised zoom lens - this means that you can zoom in on the animals around 100m if need be, and still get an HD image (32x zoom is also available if this is not enough).
  • An IP66 ingress protection rating so is suitable for use outdoors.
