Hi
@ramar
They are both very similar cameras in style / size, and would both work well on an entrance at up to 40m.
The big difference is how the cameras create an image at night, so it comes down to personal preference on this really...
The DS-2CD2087G2-L is a ColorVu model, so will create a full-colour image at night when light levels are very low, but if the camera is in total darkness, it will use its built-in visible white light (with a 40m range) to help with the colour imaging. So, if the camera is going to be in total darkness, you need to be happy with the camera illuminating the scene with visible light. However, if you have some background light in the scene, such as a streetlight, then the camera will be able to create a vivid colour picture without using its own light.
The DS-2CD2086G2-I is a Darkfighter model but also has IR. This means that it will switch on its IR LEDs in low light to create a black and white picture - the benefit here is that infrared light is invisible to the human eye, so you will just see a few dots around the camera (which are the IR LEDs).
In short, if the scene will be pitch black at night, then the DS-2CD2086G2-I is the more discreet option. But, the DS-2CD2087G2-L offers the advantage of colour at night, provided there is a little ambient light to help it with this.
Oba są bardzo podobnymi kamerami w stylu / rozmiarze i oba dobrze sprawdziłyby się na wejściu do 40m.
Duża różnica polega na tym, jak kamery tworzą obraz w nocy, więc sprowadza się to do osobistych preferencji w tym naprawdę...
DS-2CD2087G2-L jest modelem ColorVu, więc tworzy pełnokolorowy obraz w nocy, gdy poziom światła jest bardzo niski, ale jeśli kamera jest w całkowitej ciemności, użyje wbudowanego widzialnego białego światła (o zasięgu 40 m), aby pomóc w obrazowaniu kolorów. Tak więc, jeśli kamera ma być w całkowitej ciemności, musisz być zadowolony z kamery oświetlającej scenę światłem widzialnym. Jeśli jednak masz trochę światła tła w scenie, takiego jak latarnia uliczna, aparat będzie w stanie stworzyć żywy kolorowy obraz bez użycia własnego światła.
DS-2CD2086G2-I to model Darkfighter, ale ma również IR. Oznacza to, że włączy diody IR w słabym świetle, aby stworzyć czarno-biały obraz - zaletą jest to, że światło podczerwone jest niewidoczne dla ludzkiego oka, więc zobaczysz tylko kilka kropek wokół aparatu (które są diodami IR). Krótko mówiąc, jeśli scena będzie czarna jak smoła w nocy, to DS-2CD2086G2-I jest bardziej dyskretną opcją. Ale DS-2CD2087G2-L oferuje przewagę koloru w nocy, pod warunkiem, że jest trochę światła otoczenia, które mu w tym pomoże.
