What device to connect NVR to WiFi network?
codlord
Gives a lot of help
I have a NVR somewhere with no phone line/network. But it is within range of a WiFi network, so what is a good/cheap device to connect to the WiFi and then have RJ45 port on the device connecting with network cable to the NVR to give it network access?
I looked at WiFi range extenders with an RJ45 which may work but of course I don't want/need to extend the WiFi range so don't need those features.
Or do I just need a router that supports connecting TO a WiFi network and if so what are the technical terms for this so I can search for a compatible device?
p.s. I don't want to use powerline adapters, just a single device at the NVR.
