Harri Whipp
Administrator
If you need to update multiple cameras (must be the same model) but don't want to do them individually there is a simple solution.
First go to your Vivotek IW2 software and search for your devices. Once this is complete, click the drop down button.
Now select the devices that you would like to update.
To the left, click 'Upgrade Firmware(s)’.
Now this window will open. Click ‘Select Firmware’.
Now locate the firmware on your computer and select it.
Once the file is uploaded, click 'Start Upgrade'.
Your devices will now upgrade.
Note: This may take some time depending on how many devices are being upgraded.
Once this is complete, a window will pop up telling you how many were and were not successful.
If you have any further questions, please don't hesitate to contact us.
Harri
use-IP Technical Assistant
Harri
