Update Firmware - IP Camera - DS-2CD2142FWD-I
grubee
Hi guys,
Im not sure if there has been much said about this, but is there a need to do updates in a certain sequence to bring the camera update? Or can I just pick the latest update and do that one?
I have four Cameras with firmware below:
Cam 1
DS-2CD2142FWD-I
V5.3.6 build 151105
Cam 2
DS-2CD2142FWD-I
V5.3.6 build 151105
Cam 3
DS-2CD2142FWD-I
V5.3.6 build 151105
Cam 4
DS-2CD2142FWD-I
V5.4.1 build 160525
Camera Firmware from here I believe which hopefully copied and pasted looks like this:
Cheers,
Greg.
Try jumping to the very latest.
If you encounter problems - try with the previous major version.
i.e. if 5.5.5 does not work, try 5.4.5, etc.
Thanks Phil! I will give it a try tonight.
On a side note, VCA says no device available, will this be because of the older Firmware on the cameras? The NVR is uptodate.
Cheers,
Greg.
