I'm new woth hickvison. I just bought an brand new IP Cam DS-2CD2442FWD-IW with the following firmware:
The firmware seems up-to-date (it not so easy to find current version on different Hickvison server)
First it seems, that the plugins for current chrome and firefox versions doesn't work (I tried to install it, but all tries fail).
Then I downloaded the iVMS4200 for Mac, version 1.02.05.02. After some investigation I could activate the cam and see the livestream.
Then I tried to enable motion dection and email notification, after some youtubes and web research, email notification from the iVMS SW works.
So gmail should be configured in the right way. It seem, its not an issue with google mail.
I tried to configure the cam for email notificatioj, but this fails .......
As you can see, it's a new surface to configure, I could find an example using this. Testing it results in this message ..
Failed to send test email, please check the email settings (should not the issue see above) or network connection There are no firewall issues.
Any idea whats happen? Many thx in advance.
Peter
Peter
