ConfusionMaster
Hi all.
Having similar issues as Stani Emerson John seems to have had in this Thread.
Model : DS-7208HQHI-K1
FirmWare Version : V4.20.000 build 181129
Cameras : 4 x Analogue
The system is working has been working fine since I got it and set it up.
However I now want to add another analogue camera, however on the cameras page although i could select the button from IP to Analogue, it wants a restart and after a restart the changes haven't saved.
This is where I looked at other settings, and every time, although it look like it accepted the change, you need to restart for it to set, but on restart the settings revert back to as they were.
I have also tried, resetting the system and a factory reset, neither changed anything.
I have tried updating the firmware to V4.21.000 build 190722 but, even that changes nothing. I get no error message that it is a wrong one, it looks like it's updating, you get the updating progress bar which completes and then reboots, but it's groundhog day, nothing has changed, firmware is still reported as the old one.
box
I have tried all the above first directly on the box (update was done with USB plugged directly in box) and secondly via the browser interface (update was done with USB plugged into laptop)
I have also re-initialised the HardDrive.
I have looked at the manual and there is no indication of a button, or button combo to do a hard factory reset.
Any ideas?
box
Any ideas?
