AveryFreeman
Hello,
I am trying to keep a new DVR we just purchased from having the admin account locked out basically as soon as we put it online
Our issue:
We have several people who view our CCTV system remotely. We put the standard ports, e.g. 80, 443, 554, 8000 and 10554 on the net with access from any IP (our firewall can only limit access to either 1 IP or all IPs)
Our current DVR has already had the admin account locked out due to people trying to hack the system. AFAIK they have not been able to get in, but due to failed password attempts the admin lockout has prevented us from doing any further modifications of the network settings, etc. without physically being at the computer, presenting a major inconvenience and stifling a lot of our plans
Consideration:
People currently using the system are in some cases elderly, unappreciative of change and in some cases not technically inclined. Changing from default ports, etc. will require meeting with each person to give them proper new settings
We were planning on getting a new DVR anyway, and now it just arrived, but I wanted to go through a checklist to see in which ways we can keep this problem from happening in the future.
Here are some of the ideas I have so far:
At the gateway/firewall level:
1) set up syslog server to record log of IPs accessing network on CCTV-access ports, geo-locate IPs and block if suspicious
2) Change DDNS name - hackers already know our current name and can do a port scan to find new open ports
On DVR:
1) Change admin name - if hacker doesn't know to enter 'admin' for username, makes one point harder (is this even possible?)
2) Add a second (or third) admin account in case of primary admin lockout
3) Change all standard ports to be above 10000 - just make them random strings of numbers between 10001 and 65535
What do people think of these ideas, and are there any obvious steps I am overlooking?
Our issue:
Consideration:
On DVR:
