We have recently bought a hikvision system consisting of 37 cameras:
DS-9664NI-I8 (8x 4TB WD Purple NV, RAID-6, 3.4.90 build 160926)
DS-2CD2142FWD-I (5.4.1 build 160525, 5.4.0 build 160511)
DS-2CD2742FWD-I (5.4.0 build 160401)
Powered by multiple HP Procurve 2920 PoE+
Of the 37 cameras we had installed in October, 2 had developed strange faults:
Cam 1:
Connecting to the NVR with iVMS-4200, Select Cam1 for live viewing.
Selecting Main Stream shows the Sub Stream.
Selecting Sub Stream, the camera fails to open.
Directly connecting to the cameras IP:
Selecting Main Stream for live view, shows Main stream
Selecting Sub Stream for live view, shows Sub stream
Tried reset to defaults, power cycling camera, leaving it off for 30 mins, removing camera from NVR/adding to different IP channel.
This camera is being returned via RMA.
Cam 2:
Connecting to the NVR with iVMS-4200, Select Cam 2 for viewing, main stream displays fine.
Select Cam 2 as part of a multi camera view (thus attempting to view Sub-Stream) - given the error :
Reconecting.Error Code HCNetSDK.dll[91]
Any idea what might be causing this? Have we just been unlucky with faulty cameras?
It seems strange that the NVR cannot view certain streams, while both streams appear to work fine when directly connecting to the camera.
Cam 1:
Cam 2:
