I am buying a CCTV system for my house. There's nothing particularly valuable, it's for reassurance and to deter Halloween egg throwers, etc. I've read a lot here (thank you!) and think I've worked out what I need but would appreciate any comments on misunderstandings or things I've omitted. Below is a plan of the property.
Red lines are the house, garage and outbuilding, green blocks are doors. The blue line is the boundary, thick lines where it's 2m high and thinner where it's 1m, and dashed at gates. Where necessary cameras will be angled down to cut off at the top of the boundary fence.
I'm planning all Hikvision. Two DS-2CD2345FWD-I 4mm Turret cameras mounted vertically on the wall near the corners of the house, 3m up to keep them out of reach. Then one DS-2CD2545FWD-IWS (or -IS) 4mm Dome about 2.4m up mounted horizontally on the soffit under the eaves of the garage, so that it covers the front of the house.
I intend a DS-7604NI-K1-4P(B) NVR with a 4TB drive, connected to the Turrets using POE. It will either be in the loft space of the house with cables down the walls or on the first floor with cables run internally and through the wall. I wasn't planning to put microSD cards in the cameras.
The dome camera on the garage will either use WiFi and a 12V supply or Powerline ethernet and a POE injector. Since the camera has audio I'm assuming I would be able to add an amplifier and speaker later, if I wanted to speak to anyone in the area around the front door. Or I might add a DS-KB8112-IM at the front door.
I have some knowledge of ethernet configuration and intend to set things up so that I can view the live feeds and recordings from PC, tablet or mobile. I will use Cat5e. Is it usual to put CCTV on a separate subnet or just in the normal home network?
What effect do PIR operated external lights have? Do I need to shield them so that they don't shine at the camera?
Thanks for your help.
