I've got a 7608-I series that I have successfully setup with five outdoor cams. All equipment is on the latest firmware. Tonight I tried to add a new 2CD2455FWD-IW cube camera to my system for indoor monitoring via plug and play. The prior five cams added without any problems, but this one is being stubborn. When connected to my NVR, the status light on the camera below the lens lights up and blinks blue, which indicates it is communicating with the NVR. On the back of the NVR the yellow and green lights are fairly steady, blinking once in a while, but not rapidly like the other five cams. I even switched ports from #6 to # 7 and then #8, but nothing has worked. On the camera live page, it just says "detecting camera" forever. On the config camera management page, it says "offline detecting" forever. I even tried a hard reset by holding down the button under the SD card slot for ten seconds while rebooting, but that didn't help.
Any ideas why this camera is giving me trouble? I really hoped to have it installed and running this weekend.
