NVR turns itself off and on
Dubs
Hi all, I am seeking some help please. I have a hikvision system and whenever the NVR is connected to my network the NVR continually turns off and then back on - once it reboots it turns off and then on again.
rinse repeat
I have no idea what would be causing this.
I have tried different cables, plugging the nvr into my switch, plugging it direct to the router to no avail.
You don't mention what model NVR.
I would check the firmware version and try to get it to the latest version.
You may be able to do so via a direct connected monitor and the firmware on a USB stick i.e. without a network connection.
NB I have heard of this boot-loop symptom, but never experienced it. I wonder if it occurs with products intended for the Chinese market (not Western region).
If you purchased it via ebay/Amazon or some other non-authorised seller you might want to speak to them about the problem and follow their recommendations.
Bought from a local supplier here in west oz to avoid language issues.
NVR
DS-7808N-E2/8P
Firmware V3.0.8, Build 140825
Encoding Version V5.0, Build 140816
Cameras:
3 x DS-2CD2332-I
2 x DS-2CD3332-I
All 5 cams are V5.2.5 build 141201
Thanks for the help folks
I'm afraid it's not an NVR model that was ever sold in the UK / Europe.
It's not a model I'm aware of.
Not mentioned at their European download portal:
DOWNLOAD PORTAL
If you disconnect the NVR from the LAN/internet I've read reports of that helping to stop a boot-loop whilst you try to resolve the issue.
