Hello
I am getting ready to purchase a Hik DS-7608ni-i2. The cameras that I'm going to connect to it are the DS2C6D54RWD-IZHS and DS-2DE7530IW-AE, both require POE and they both came with midspans. I have other cameras that I may add to it later.
The only version of that NVR available to me comes with POE ports that can be individually controlled regarding power (on or off). I looked at the spec sheet but it's unclear to me whether or not that NVR would supply enough power to the two cameras on its own. I didn't see anything stating the max power per port. If not would I just stick the midspans in line or shut off the internal power to the ports and use the midspans??
thanks
thanks
