Good morning,
NVR: DS-7608NI-E2 / 8P/A – V3.4.96 build 170921
Cameras: DS-2CD2142FWD-I-4MM (4 off) – Default firmware from 2016
Hope you guys can help and great forum
We had 2-3 power cuts in quick succession (no UPS!!) and when I checked my cameras a few hours later I got nothing on my devices, connection failed.
I went to the NVR and it was asking for a new password and to confirm the password and also for a camera activation password. I upgraded to 3.4.96 about a year ago and never had a separate password for camera activation. I put these in (I used my old password for the NVR but changed the activation password to something different) and then was prompted with language selection, date and time and these rest of the wizard. I exited the wizard as I thought I was all setup.
I was also asked for a password sequence which I have never done before.
The network settings had gone too and I have no cameras visible.
1. What is the best process to get setup again? I think my configuration has been wiped as my Hik Connect is showing offline too. Happy to reinstall if necessary. Return to factory default?
2. Are the cameras locked to previous setup? Do I need to use SADP tool?
I am competent at plugging directly into the NVR and/or cameras if required.
Thanks for any assistance
